Upper Control Arms
Nickv1214
I had a 3.5” ready lift for about 38,000 miles, pretty much since brand new on my truck from 2019 , I’ve replaced the entire lift now with the 3.5” rough country set up ,also added in , front suspension max end links and rear track bar . ( just hated the ready lift always rode terrible ) I went in for an alignment today and turns out the only item that I left from the ready lift was the upper control arms and both sides the bushings are worn out . Does anybody no if ready lift sells replacement bushings ? Or should I just go with different A arms , if so what brand . Thanks
Give them a call I’m sure they”ll sell replacement bushings or provide the p/n for whomever they use.
bushings are wear items i'm sure they have a P/N somewhere that you can swap.
as for replacement arms... i only recommend Carli and Thuren but both are bank and i'm not entirely sure if they will work with non-performance lifts
For anybody interested part number on replacement bushings
ready lift 47-64438
