upper control arms 2-4 lift 2025 model shows different part# yet rough country shows same through 2025
motomarc
Oklahoma
so my question is are all the upper control arms the same from 2006 up or is there a true change in shape and size / spacing etc.
I am looking at getting the front leveling loaded struts from rough country.
thinking I should go ahead and get the UCA at same time??? yes or no???
they show oe upgrade as typically purchased with it not the 3"-5" UCA.
so guessing no need if just leveling it with the struts???
do the stock ball joints have enough movement? and angle for the level? or should I get a KSP 2"-4" UCA off eBay or amazon for $150 or less.
the most off road it will see is fire roads I just want it level it looks like crap with the front down.
thank you in advance. MM
Did you ever find anything out on this? I have the Mopar 2" lift control arms on my 25 bh but running the fox coil overs. I didn't realize the 2025 had their own part number. I held them up to a pair of arms from a 23 bighorn and they seem the same. Just wondering if the 25 maybe has a new bushing or something. Visually the 23 and 25 arms look the same to me. The Mopar lift arms clearly have a better ball joint angle than stock.
