Upgrading to Laramie seats.
Doom515
Howdy,
First post to the forum. I just bought a '23 Ram 1500 CC with Big Horn Lvl 1 trim(Uconnect 5 w/8.4" touchscreen). It has cloth upholstery with heated front seats and driver's seat is power. I have an opportunity to upgrade to Laramie leather seat but have questions on feature upgrades and wiring. The Laramie front seats are both Power/Heated/vented. I have an 8.4" touchscreen but comfort controls are limited to enabling/disabling the Auto seat heater.
Questions:
1. Will the existing wiring support all those features without physical modification?
2. Can a dealership turn on the control features for the vented seats?
3. Is the reclining rear seat a direct install or are physical modifications required?
Thanks,
Thaine, KS
2023 Ram 1500 Big Horn CC/4WD/LWB/LB 5.7 eTorque
Howdy,
Questions:
Thanks,
Thaine, KS
1. Don't know, but you can use search.
2. Absolutely not. You will need to do it using AlfaOBD or JScan.
3. As long as you have all the hardware, yes.
the reclining rear seats have a different cab wall connection, they also fold down with a pull string on the back of the seat. non reclining seats have a hook on the cab. not a direct fit on the rear.
Howdy,
Questions:
4. Can any one give me a part number for the seat switch module which includes Heat/ventilation/Steering wheel?
I have seen the dual zone control stack bezel with heat and steering wheel only and with heat/vent /steer switch. I just want to add the ventilation feature physical switch to my existing bezel.
What I have.
What I am hoping to find as a separate item.
bumping this thread to see if you were able to get them installed, looking to do the same.
