Unplugging air dam deactivates rear camera and other functionality.
howster
I want to unplug the Air Dam to triage a U11E9 Active Grille Shutter code but it ends up deactivating my rear camera.
Any way to unplug the Air Dam without disabling other functionality.
2019 Ram 1500 Laramie.
Thanks.
That's the plug I disconnected. Is there another plug on the air dam
Active grill shutter is in your grill.
The picture you provided is the active air dam.
2 completely different systems.
The rear camera also has nothing to do with neither.
Maybe you created a ground, when you unplugged whatever it is you touched did you wrap both ends in plastic/seal them from the weather?
The code you listed has nothing to do with that plug or system, it's for the AGS in your grill.
