UCA's for a 6" inch lift!!!!!!!
Wyno
I need some help if anyone has any knowledge in this area. I have a 2021 1500 Bighorn that I'm currently running a 3.5" SST kit with 20x9 o offset wicked wheels with 35x12.50x20 mickey thompson tires. I'm in the market for a 6" lift and have to get new uca's because the readylift ones won't work with the 6" lift. I was looking at the zone 6" with the zone uca's but the zone arms say maximum backspacing is 4.5" . My current wheels backspacing is 5" Is this a problem? I'm not trying to run spacers, tires already stick out close to 2 inches. Or is there other uca's that will work with the zone kit or do you have to keep same arms with the same lift kit. I liked the zone for the price but will go BDS if I have to.. Wasn't trying to buy new wheels either. Any help would be apreciated
mplaramie
The backspacing is the minimum recommended to use the UCA's. I think the BDS backspacing is also 4.5 or 4.75 so you should be ok with either lift. If you are still concerned, check out Core 4x4 UCA's. They are designed with maximum adjustability for all sizes of set ups.
Good luck!
Wyno
So your saying that 4.5 is the minimum, I though that was the max. So I should be fine with either set up. Thanks for the help and im gonna check out those arms now.
