Recently, I had to jump my 2019 Ram 1500 after not being driven for five weeks. Everything worked fine for several days. I left it at the airport and when I returned the screen would reboot every 3 minutes or so.
Also, my battery went dead several times after. I got my amp meter and measured 3amp being pulled while the truck was “asleep”. After several trouble shooting methods, I narrowed it down to the radio. I pulled the fuse and remeasured the draw and it dropped to less than .5 amps.
I original converted from a 8.4 to 12” for a quick background. Today I unplugged each connector on the screen console. No change. I started to disconnect each connector on the “brain “ it only change after I disconnect the main plug. Long rectangular one. I disassembled the 68329882AJ and began to test the boards. I’ve narrowed it down to part M3J4102474 as the culprit.
My question is what other part numbers are compatible as a replacement for this board. I can’t determine what on the board is bad, thermo camera is coming tomorrow. Also, I did unplug the hard drive as well to test if it was the problem before determining the board is the issue.
Also, GPS is not working. It thinks my position is 45 miles away.
