U Connet issues
Rich_Neagle
I have a 6 day old 2019 Ram 1500 Laramie with the Black appearance package. Any how the truck is super nice. However the damn USBs will not connect to my Galaxy Note. I plug it in, and it keeps charging and un charging. Android auto won't work at all.. says error connect.. It worked perfect for 3 days, then nada. I uninstalled the app made sure it was up to date. And went and got an ATT $30 ",Android cable" still not working. Before I drive over an 1hr back to the dealership am I the only one ? Or does anyone have some advise?. Never had a Ram ever. Always Tundras. Its a sweet truck except for that part..
Love Rich
Mine works fine in my 2019 Limited. I have the Samsung Galaxy S9+. Have you tried the USB C connection?
Try deleting phone info from Uconnect, and delete app off phone. Then just plug your phone into usb let everything load/download by itself
Someone on here a long time ago mentioned a specific cable they had good luck with. So I bought it and thus far, no issues.
I also own a Note 8.
Nekteck USB-IF Certified USB C 3.1 GEN 2 Cable(10Gbps/100W) USB C to USB C Cable (Thunderbolt 3 Compatible) with E-marker & Power Delivery For MacBook Pro Galaxy S9 S9 Plus OnePlus 6/Black 3.3ft https://www.amazon.com/dp/B0718Z1MWF/ref=cm_sw_r_cp_apa_VYs0BbZNVWREF
i have the exact same problem on my 2019 limited with the 12inch
i think it might be some sort of a short in the usb ports in the car. but i'm just guessing. i contacted ram care about this and someone was supposed to call me back today. but they didn't i will have to call again tomorrow and probably talk to another clueless receptionist for an hour trying to run me through obvious steps like... try another cable or try disconnecting and reconnecting.... until they transfer me to someone who actually knows the system
Have you tried other USB ports? Doesn’t sound like it would be software in the Uconnect. If it were a driver type issue it probably wouldn’t connect at all. Maybe the port was attached to the board poorly and vibration broke a small fracture in the connection.
I have a 6 day old 2019 Ram 1500 Laramie with the Black appearance package. Any how the truck is super nice. However the **** USBs will not connect to my Galaxy Note. I plug it in, and it keeps charging and un charging. Android auto won't work at all.. says error connect.. It worked perfect for 3 days, then nada. I uninstalled the app made sure it was up to date. And went and got an ATT $30 ",Android cable" still not working. Before I drive over an 1hr back to the dealership am I the only one ? Or does anyone have some advise?. Never had a Ram ever. Always Tundras. Its a sweet truck except for that part..
Love Rich
Were you ever able to get this resolved? My front USBs are charging/not charging, and the system doesn’t recognize anything plugged in. Tried 4 or 5 cables and 3 phones, all charge when first plugged in then stop.
My truck had this exact same issue when I first took delivery (charge/no-charge constantly cycling). I immediately had service take a look at it. They spent the day disassembling the console/USB's and could not find an issue. The tech called me and said he was putting everything back together so that I could have my truck back for the weekend, but I would need to make another appointment for further troubleshooting. When he reassembled, the USB's started working. I now have 7000 miles on my truck, and have never had it happen again. I use CarPlay, charge my phones, etc...no problems. I think there is a grounding issue coming out of the factory, that the tech resolved when he put it all back together.
I had the same issue with my Pixel 2 from Verizon. The phone was continually trying to charge/use data and couldn't decide what to do. After staying on the phone over 2 hours with Verizon the other day, they had me completely wipe my phone and reset everything as if it were a new phone. It started working! We will see how long that lasts.
I have the same issue, anyone solved it? I have a Samsung s9 + and also tried with the new note 10+ same with both start charging than stop and starts again and so on. Sometimes the car says on the screen device not supported.
I've been having the same issues. One thing I've found. . . If I take my fully charged phone and plug it in, it works fine. . . If it's not fully charged, it goes on and off. . . .
I'm suspecting that these new phones are pulling too much current to charge it. So I'm going to experiment with different cords to see if I can find one that will limit the draw on the USB to charge at a lower rate.
I found that mine only worked with the cord that came with the phone (I use the usb c connection). I believe other cords will work if they are rated appropriately. I saw on another thread that the issue was with the internal connection on the usb ports being bent.
Check this thread... This had been my biggest PIA since I got my truck. Finally fixed:
