- May 13, 2025
[Staff Approved Post]
Hello, 5thgenrams forum.
My name is Troy Rutherford, owner of Dirt Church Industries.
I have been in the automotive, off road and outdoor industry since I was old enough to hold the flashlight while my dad worked out in the garage.
I recently came up with a design that allows you to mount the twin ARB compressor under the rear seat of your 2009-current Ram truck. The kit uses the ARB rocker switch which is located on the passenger side of the rear seat.
If you own one of these trucks you know that space is very limited to mount the twin ARB compressor under the hood, Ram likes to use every square inch of space available. This kit is 100% complete with very detailed installation instructions. 6 gauge duplex marine grade wiring is cut to length, properly crimped terminals, heat shrink tubing installed, 80 Amp fuse breaker, powdercoated 3/16" thick steel brackets, 25 foot airline, fittings, hoses, couplers, 1/4" air line, as well as a hammer lug crimping tool provided that will allow you to crimp the final two terminals on your end.
Trucks these days are very expensive and we understand the value of time. We did not want to create a half finished kit that required the customer to spend half the day driving around sourcing parts to finish out this product. This kit can be installed by the average person in their garage with basic hand tools. Installation time will take ~3 hours and utilizes the ARB rocker switch, so no external up-fitter swtich is requried.
This kit will is 100% complete with the exception of the ARB twin air compressor PN CKMTA12, excluding the compressor no additional sourcing of parts is required for installation.
NOTE: This kit will only work with the brushed ARB compressor, not the new "Brusheless" compressor that was released in April of 2025.
I look forward to answering any questions you may have
Product details can be found HERE.
