Trying to decide on off road group (AWL) package for a 2025 tungsten
drjbeyer
Getting ready to place order and that's the only package I'm on the fence about. The build sheet says something about decals (MPD) which I'm not a fan of, but it also says you get Falken tires (I'm assuming AT3) which for me would make the package worth it for that alone. Anybody have a pic of one with the off road package? Wondering how much it changes the look of the exterior on those 22's
Thanks.
Assuming this package yields in the 25 what it did on the 24, it gives you a 1” ride height increase. And the fallen tires are not the o es You are thinking of - they are the AT3/W not AT3, so you might google the difference. Still good tires as I understand it, just not the aggressive option you might be thinking.
Also I assume Tungsten comes only with air suspension. In this case that 1” lift is simply reprogramming the air suspension to ride 1” higher in normal mode. If that matters to you.
On an air suspension truck the best parts of the off road package are rear locker, skid plates and tires, all of which you can get a la carte or better on the aftermarket.
Hi, thanks for this good info. I'm not familiar with, nor am I able to find the differece between the Falken AT3W and just an AT3? Do you have more info on this?
Thanks.
If you are placing an order you should have an option for decal delete (at least that used to be an option on 5th gen). I've also heard the OEM Falkens are not the same and might be non 3 peak rated and lower treadwear.
