TRX Takeoffs on 275/65R18
TGGood
I’ve been doing a lot of research but the bad part about the internet is conflicting info.
The TRX Takeoff wheels are 18” so theoretically should fit on my tire, BUT is there anything else I need to know regarding width, trimming, other measurements?
I want to pull the trigger, thanks in advance.
Wheels don't fit on tires so I'm not sure what you're asking here. Your factory tires will fit the TRX wheels just fine. They aren't a recommended size as the wheel itself is 9" now, so the 275 is "officially" not supported.
I have been driving with the factory 275s on TRX wheels for over 2 years now without issue.
Apologies with the vernacular, layman is an understatement for me with this lol.
Getting the work done today, appreciate the info.
If you're putting the factory size TRX tires that come on the TRXs, you will 100% rub bad if you're still stock suspension. You need wheel spacers and at minimum a leveling kit, and even with that you'll have to do some minor trimming and or bending of the wheel liners.
Thanks for clarifying that, firemedic. I only responded to the fact that the tires will fit the rims, but didn't elaborate on the rest. As mentioned, I'm running stock tires on TRX wheels, but I also have 1.5" spacers and the Bilstein 5100 level.
Hey gents, I was only looking to replace my alloy Tradesman wheels with the TRX wheels. They worked no problem on 275/65r18 tires, stock suspension.
