Truck height after leveling kit
JulepeRAM
I currently have a 2019 1500 Bighorn completely stock but will like to level it and add 35’s. Can someone with a similar setup confirm what the truck height will be? I live in a building with a 6’8” garage...
Welcome to the forum!
You didn't furnish many details about your truck. Current wheel & rim size? 2WD, or 4WD?
Pls add your truck's vitals to your signature when you have a moment. This makes it easier for other folks to help in case you have questions or concerns about your vehicle.
It’ll probably be 6’8 or 6’9. If you have air ride you can probably make it, otherwise I wouldn’t risk it.
For reference, my truck is 6'-6.25" to the top of the shark fin with OEM 22" wheels and OEM Goodyear tires. These are about 32.1" in diameter.
Use this site to see to compare tire height with different options:
Cheers,
