Trouble Calibrating 360 Camera Using AlphaOBD – Need Help
MileHighSteve
I’m having some trouble with the 360 camera calibration on my truck using AlphaOBD. I was able to successfully calibrate the left, right, and rear cameras, but the front camera is giving me problems.
Here’s a video showing the issue: YouTube Video.
These are the steps I followed, which worked fine for the other cameras:
  1. Login to radio
  2. Select CVPM Service Calibration
  3. Select the individual camera
  4. Perform calibration
  5. Go to status tab and clear codes
  6. Go to manual connect and enter 8502
  7. Go to status tab and clear codes
  8. Go to start disconnect (it will still show connected)
  9. Go to status and clear codes
  10. Go to start and connect
  11. Go to status and clear codes
  12. Then calibrate another camera.
While this process worked for the left, right, and rear cameras, the front camera refuses to calibrate. I’ve tried driving around in a parking lot for a couple of hours, but it always fails.
Has anyone experienced this issue before or have any suggestions for what I could try next? I’m open to any troubleshooting tips or ideas that might help.
Thanks in advance!
