So I just got my tuner and unlocked pcm today. I was looking around online for install info and ran into a procedure on the diablo forum:
Basically says that you put in the OBDII gateway bypass, and start tuning with the stock pcm installed. That way you pull your current stock tune into the T2. Then you do the pcm swap and install whatever tune you are going to use. Any of you guys that have the T2 with a spare pcm, is this what you did? The skimpy instructions that came with the unlocked pcm start with swapping the pcm's.
