Possibly a TSB about hard shifting, cured with re-flashing the TCM.Has anyone done transmission relearn from the dealer, if so around how much? Also I have a 2019 North edition 45k miles and experiencing some hard shifts.
Was gonna try resetting TCM with the gas pedal methodPossibly a TSB about hard shifting, cured with re-flashing the TCM.
Try a search on it?
If you have either the AlfaOBD or OBD JScan apps, and a Bluetooth OBD II connector you can do it yourself.
Sent from my CPH2749 using Tapatalk
That only recalibrates your throttle body, nothing with transmission.I don’t have either one, was gonna try resetting try resting with the gas pedal method
