So I activated the brake controls with JScan on the dash and radio screen which comes up but when I connect my trailer it doesn’t recognize it and still says trailer brakes not connected. Am I missing something?
Not to be insulting, but you are using the 7 pin not the 4 pin, right?
Grab an ohmmeter and check the resistance on the trailer between brake and ground pins. Also check the trailer brake fuse, which should be F25, a big green 40A fuse.
Yes, you are and my 2022 has been doing this since 150 miles, and with any of my 5 trailers......you can contact me at 314-280-1656 and I will tell you your problem
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
