Sigfla
- Dec 29, 2023
So after going to a larger tire I decided to jump into the TPM rabbit hole to see if I needed to adjust my limits. I found this comparison site that lets you put your stock size and pressure in then it calculates your new pressure with the new tire. Turns out my new tires are only a few psi off and likely won’t need TPM adjustment. I have no idea what the stock limits are but 36 to 39 psi is prob fine. Tire Pressure Calculator
