Towing
chewy1
I have a 2023 ram 2500 hemi. With 410s I'm looking at a 11000 lb gross fifth wheel. Pin weight 1630. The truck empty is 7000 lbs.per the scales. 10000 lb gvw and 3800 payload depends on what chart you look at . With the pin weight mostly 2 humans and my furry friend 100 lb lab, some cargo, 2 propane bottles .a 200 lb fifth wheel hitch I'm a couple of hundred pounds below gvw, and payload. And good on cgvw. 17500 towing . I know the truck is capable . My question is I'm just looking for people who have towed a simular set up with that simular truck, on your experience towing it. Going across the country with it. I can go smaller if I choose thanks for your reply s
You'll probably get more replies on the hdram forums, this forum is more for the 1500:
