itsjoebaker
- Jul 4, 2025
Looking to upgrade intake, headers, and exhaust on my 2023 Ram 1500 5.7. Any recommendations that would improve torque and towing power with the deep rumble?
Who is the member that just did headers and a limited slip diff?Not sure if any canned tunes will play well with a truck, think most are marketed for cars. Would also have to switch to premium gas. And any tune is an instant void of the drivetrain warranty. Without a tune, no mod will increase power. And if there are other mods, no canned tune will take advantage of them; custom tuning then required.
Pick any catback exhaust you like the sound of. No power add, but might enjoy it.
Are you RWD or 4WD? And what final axle ratio? My 5.7 4WD Rebel has 3.92 axles, there is no shortage of torque. Depending on what gear you have, this might be the best way to increase torque. Obviously a more expensive conversion if you need to do two axles.
If your final drive ratio is 3.21:1, a swap to 3.92:1 is an instant 22% increase in torque. That is huge. And it will tow fine with 89 octane and otherwise stock. If you have 3.55:1, then the swap is still a 10% increase.
The A8 is an amazing transmission. I have not towed with mine yet, have hauled *** a few times getting up to highway speed and my Rebel just pulls and pulls. I did test drive the other gears and I feel a difference which is why my search focused on a Rebel or a truck with similar equipment.... You can't separate the rear axle from the transmission gear, and if you do the math both trucks have very similar final gear ratios to choose from outside of 1st in the 3.92 and 8th in the 3.21.
As far as the math, you are correct. There is basically a gear which is the same except for what happens in 1st or 8th. How the programming makes a selection, or how much tow/haul changes selection points and gear holding, or how much the driver can limit top gear (cumbersome steering wheel buttons), these can make some difference.
For a cam, I have read some good things an about the Truck Norris cam, it is a popular choice in the Charger and Challenger groups. The name suggests truck but it seems to help in the heavy sedans. I still lean towards gears before cams as a general philosophy but happy to move the conversation to alternatives and how they might improve the towing (and general driving) experience. I lean towards gears before cams in part because I have seen many builds (not Ram or even Mopar specific) which simply do not "wake up" until the final gear gets set to take advantage of engine mods.
