Tow Mirror Glass Swap
mmei627
hi everyone
just got a 19 ram laramie and new to the forums. i have the tow mirrors which i didnt think of when i got the truck. after i drove it off the lot i realized i absolutely cant stand the right side because i just cant see my blind spots. is there anyway to just change the glass to a regular objects may appear closer glass? i called parts and they said it cant be done. thanks in advance and glad to be part of this community.
This may be a dumb question but did you try to rotate the mirror up and see if that helps? The mirrors are usually set up horizontally when you get the truck but the whole mirror assembly can be rotated to a vertical position and that may be better for you.
Just buy standard mirrors and mount them. You cant change the glass..
