Tire pressure after going up in tire size
Dan Houle
Lake Alfred Florida
Hey all, went up in tire size on my 2022 Rebel from the stock 275/70/18's to 35" 12.5 BFG KO2's. The door says 45 lbs of pressure but the new KO2's say 65 max PSI. Which # is correct? I asked the dealer that put on the KO2's & he said follow the door. I was just double checking. TIA.
There is a website where you can enter your data and it will give you the pressure to set tires to. I used it when I went to 305/45 22 on my Limited. One moment....
Found it: Tire Pressure Calculator
