Timber Groves air leaks
frisby5
i just installed a pair of Timber grove airbags and now im chasing a air leak anyone have this issue after install? I cant get to the two hose ends at bags without taking apart. Any suggestions ?thx
To find a leak, use a spray bottle with dish soap and water and spray at every connection when the system is inflated. Eventually, you should see bubbles appear where the leak is. Remove the lines, make a fresh cut with a razor blade so the cut is very straight, then push the lines back in. Are these the CRMs or ASAMs? I have the CRMs and although it is pretty difficult, I can get to the lines at the top of the bags. You can use one of those mirrors on a stick to see those hard to get to lines.
Mine are the ASAMs ,its almost impossible to see the tops through the bump stop mounts. But i think i am going to recut the lines to make sure the cuts are straight. I will try a mirror and use some water /soap to see if i can see leaks.
