Third brake light keyfob interference?
Mbrigh3
Has anyone found a led bulb that doesn't cause the interference when using the keyfob?
Clearly this was a mistake Ram made when building out trucks. Their solution was just to throw halogen bulbs in but id like to get some led cargo lights....
Sent from my SM-G998U using Tapatalk
I have the Lasfit LED cargo lights in the 3rd brake light assembly and have no problems with keyfob.
I use Alla Lighting... they are great for the first 3 months they work... no interference but the cargo lights go bad all the time... I bought a 5-flashes red LED for the 3rd brake light and it's been working great for over a year now... I can recommend their brake light but not the cargo(white) lights...
I use Diode Dynamic LEDs in mine and haven’t had any issues. Brake light and cargo lights.
Honestly I bought some standard Sylvania LED bulbs at advance auto and they've worked like a champ for me for over a year with zero issues.
Sent from my SM-N986U1 using Tapatalk
FYI - I installed the Lasfit cargo lights about a year ago +/- and have had ZERO issues. 3rd brake light burned out a couple of weeks back so I replaced with the Lasfit model. Went 3 days with no issues and now can't start the truck 90% of the time without touching keyfob to the starter button. Also regularly losing the display settings for the 8" Nav screen and speedo. Likely pull it out this weekend until I come across a fix for this.
Thanks, Brian
