Tazer/Security Bypass install and Warranty
MTB Power Wagon
Sorry about asking a question on my first post...but here I go.
If I need to take the truck in to the dealer I realize I should remove and "unmarry" the Tazer. Easy enough but on my 20' PW I also had to install the security bypass harness.
Question is I assume I would need to also remove the harness??
I've searched some threads here and elsewhere and I'm just nervous about completing this install. Truthfully all I really care about is changing the tire size to 35's and correcting the speedo!
Thanks!!
As long as they can still access the ODBII connector, you will be fine.
This ^^^... however, if it isn't terribly difficult, consider removing the bypass just in case. For an oil change, might be safe. Anything warranty, it could be a risk.
