I currently have my amber turn signals set as the DRLs. The lights work the way I want however when I use my turn signal I continue to get an error alert in the cab. Have been ignoring it but it’s annoying.
Make sure you have drl dropout set to yes as well. Then when you use the turn signal the drl function will turn off while the blinker is activated. Not sure if that's your issue but that's how I have mine set up and it works with no errors.
Thanks for the advice. So after playing with it for a bit, I tried switching the settings for the lights to led. I don’t have factory leds but I have changed the bulbs to leds just never adjusting the settings. So far that seemed to work.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
