Tailgate Switch & LED ligths Won't Operate
JayRAM2022
Hello All:
I have a 2022 RAM 1500 Rebel 5.7L. - I was looking for a 12v cable to add an LED light under the hitch so every time I unlock the truck I can have more light under the truck's rear. (Quite dark at my driveway). The plan it's to pull 12v from OEM tailgate LED's. I disconnected LED bar lights and switch connectors and connected back. Thing is now none of those operates. I can be able to open the tailgate using both fob control and switch inside cab and tailgate open as should be. I hear somewhere there is an error if I disconnect the cables but can't find how to fix it.
Any ideas on how to reset the system? - Photo as reference.
Do you have the factory bed lights where you can push the button to turn the bed lights on? You can tap off that
