Switched Power Supply
Rock Crawler
5thGenRams Supporter
Lone Star State
I have an on-board air compressor for my Timber Grove airbags and the power is currently running straight off the battery. I would like to change it to switched power so the compressor will only run when the truck is running. I would like to keep it clean and as stock looking as possible. I would like to use a switched power slot in the fuse box that may be vacant so I can add a connector on the output side and run it to the compressor. Anyone know if this is doable? If it is not possible, what would be the cleanest way to add a switched power supply. The compressor requires a 25 amp fuse.
