Sway bar(s) replacement?
jman307
Quick question, it seems most folks here are only upgrading the rear sway bar with aftermarket, and not the front. Any particular reason? Pros and cons of just rear vs front and rear upgrade?
In previous threads, it’s been mentioned that Hellwig doesn’t even make one; they determined the factory bar was sufficient.
^^^^ what that guy said.
even with 4th and previous gens, frt sway bar is really beefy. The noodle or even lack of one in rear on some gens, is the real daily life driving issue.
Have to point out, the rear hellwig sway bar mod is probably the only none argued mod that is very lopsided positive & recommended
