Sway Bar Link question: 2021 1500 with Air Sus
dustindustin
I have the dreaded clunk and what I thought would be a simple thing to find has become cumbersome. First venture into the Ram world, and trucks for that matter, and I have a 2021 1500 Laramie with my front left stabilizer link nut backing off causing an insane clunk. It’s been off and on for about a year now but just got bad enough for me to diagnose it.
First question: since it’s been a while, should I just replace both sides and the two bushings?
Second: if I need to replace then I want to upgrade these knowing the issues and am not sure which to buy. I know suspensionmaxx has a few options but which do I want? I have the air suspension if that changes things.
I have limited with a level, and I am using the 3" lift suspensionmaxx links and highly recommend. you can email suspensionmaxx and get help they are quick to respond and very knowledgeable. I would also change out the bushings while under there.
there is an option for 19mm and 21mm nut kits which is specific to year of truck i believe so shoot them a email and they can get u taken care of
  • Back
