it is approx 4 yrs old Thanks for the tipMy Ram would not come out of first- replaced the battery, all good. How old is the battery?
Yes that is all exactly what is going on with my truck.I disconnected the battery cables and jumped a wire between the pos and neg while disconnected from the battery to drain any left over charges saw it on youtube.That helped get my truck to shift out of first but lights on dash are still all over the place I quess I am going to replace my battery even though it seems fine.Thanks again for your input It is reassurring I hope the battery solves this problem.These trucks are so electronicaly controlled.Computers are running the world.Had the rpms, speedo and gear shifter do some funky things also. It didn't come out of first but after sitting it came back.. There is a thread on this.
Info sent to "Ram Cares"
As far as the "not coming out of first gear" a member on the 5th gen forum had a similar problem (POST 335659) and was resolved with "the tech found a split PCM connector pin". This by far is my biggest concern and I am not sure how readily it can be diagnosed and resolved. Other people have complained on "carcomplaints" with not coming out of first gear. Intermittent electrical issues are probably the hardest to diagnose. We have had some heavy rain in the previous days and I do not know if this correlates to the issue. Driving habits and use has not changed in the two years of ownership, no off roading, towing or heavy loads. For the most part it is a "pleasure vehicle".
In addition to not coming out of first gear the display stated:
1. Service Electronic Stability Control
2. Service Trailer Brake System
3. Park Sense Rear Braking Assist Off
4. Service light was on (not sure if engine or traction control)
I went out an hour or so later and the situation resolved itself.
Again the battery resolved the problem.
Best of luck, keep us posted.Yes that is all exactly what is going on with my truck.I disconnected the battery cables and jumped a wire between the pos and neg while disconnected from the battery to drain any left over charges saw it on youtube.That helped get my truck to shift out of first but lights on dash are still all over the place I quess I am going to replace my battery even though it seems fine.Thanks again for your input It is reassurring I hope the battery solves this problem.These trucks are so electronicaly controlled.Computers are running the world.
New battery today all is resolved. I still can't believe it can cause all that mischief The battery still started my truck but was evidently too weak for the brain.Best of luck, keep us posted.
What model battery did you get. I had the same issue and I thought my new battery fixed the issue. It just happened again today with the new battery.New battery today all is resolved. I still can't believe it can cause all that mischief The battery still started my truck but was evidently too weak for the brain.
Modern vehicles, very reliant on a good strong battery, take care of that new battery.
Something has to be making a poor connection than. Seems plausible to check the battery related wires first.Mine has started happening when I go over a speed bump at a certain spot. Three times it has caused my truck to have the weird dash lights to come on including check engine. This has all started after I had the battery replaced.
So I am almost positive it was the fact that the idiots at Advanced Auto Parts smeared a bunch of the silicone grease on the poles of the battery before he connected the positive and negative. Then the didn't tighten them down enough. I ended up taking everything off and removing the silicone grease and now no more issues.Something has to be making a poor connection than. Seems plausible to check the battery related wires first.
*crickets*...
@ramcares…do we report this to NTSB or can you get a software package out?
