Struggling to Add Front Parking Sensors to My 2022 RAM 1500 Lonestar- Need Help Finding the Right Harness
Esalinas
Hey everyone! I have a 2022 RAM 1500 (New Gen) with the 3.6L engine in the LoneStar Edition. I've already upgraded my truck with the infotainment package to include rear parking sensors and also the digital cluster upgrade. Now, I'm trying to add front parking sensors to make everything work seamlessly, but I've run into a bit of a roadblock and could use some help.
Here's what I've done so far:​
  • Research: I found the necessary parts for the front parking sensors:
    • 5YV68TZZAA – Outside sensor
    • 5YV69TZZAA – Middle sensor
  • The Issue: I can't seem to find a proper harness to connect everything. I dissected the rear infotainment harness and saw that everything connects to a module: P68440530AC. In a video I watched, it mentioned that if you want to connect front parking sensors, you need to use the "front port" on this module.
My Attempt:​
  • I ordered an identical harness for the rear, hoping it would fit the front port of the module. Unfortunately, no luck—it doesn’t fit.
  • Dealership Interaction: I called the dealership for help, and they offered me a harness that connects to the fog lights, but not to the module I’m working with (P68489202AA). This isn't what I need to get everything working as I want.
My Question:​
Has anyone else had experience with adding front parking sensors on the 2022 RAM 1500, particularly with the infotainment upgrade? Where can I find the correct harness that will plug into the module and connect the sensors? It seems like an easy solution, but I’m not sure where to find the right part or what the next steps should be.
Any help or advice would be greatly appreciated!
Thanks in advance!
  • Research:I found the necessary parts for the front parking sensors:
My Attempt:​
My Question:​
Thanks in advance!
The port is different on the parking assist module for the front sensors. I see you got our rear sensor harness, we also have the front sensor harness available for sale for HD and DT. DT isn't listed on the site yet but call into our advisor team and they can help you out.
Right, I would gladly spend the $750 + tax. for the front park assist. The setup you guys offer for front parking assist is only for
2019-2024 Ram 2500 3500 HD Factory OEM ParkSense Front Park Assist, will it work for my 22 ram 1500? If so take my card. ;)
