Going to be a tough one to upgrade if you're just wanting a drop in replacement. The factory Alpine sub is a 2 ohm triple voice coil sub. Each voice coil is 2 ohms with a seperate channel from the amp feeding each one. Nobody makes a triple voice coil subwoofer. Best you could do is a 2 ohm dual voice coil sub, but then you are losing some power from the last channel not being hooked up.
I have the Alpine system so I am facing the same dilemma. I likely will just be adding a standalone sub and amp.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
