alow
- Jun 3, 2018
Hey I've got the stock stereo and I'd like to upgrade it for better quality sound. I know there are two threads on here already but alot HK and Alpine stuff gets mixed in and its hard to track (atleast for me) which is for which system. As well the mega thread with 40 pgs is a bit much to flip through and we all have different setups and taste. Mods if this is a dumb redundant thread feel free to close this and I'll just post up in one of those.
With that out of the way I'd like some advice on selecting and installing speakers for my truck. I like audio quality vs volume and rarely have my system up very high. I want to keep ANC. I'm reasonably knowledgeable about doing wiring though I havent done a car stereo in about 20 years. I normally listen to rock, metal and podcasts if that changes what kind of speakers I should get. I like hearing each instrument or track in what I'm listening to. I typically run my phone through the USB-c line / Bluetooth but sometimes do CDs. i'm fine spending a few hundred but I would like to keep it around 500 or so. From reading the other threads it sounds like my truck is set up in the following way?
Center - no
Corner dash - replace 1x per side
Front and rear door panels - replace 1x per door
Amp-no
Sub-no
What tools and speakers should I look into? From reading the other threads I understand theres a plastic panel popping kit which I'd happily invest in.
I've heard alot about these Kickers , i've read they are bright and tinny so I'm not sure they are what I'm looking for
but I'd buy these Infinity references if that would be better.
Is it just a 1 for 1 swap after popping the panels or do I need change out the wiring once I'm in there?
Also The above will only work for the dash and center correct? The door panels I believe I read are 6x9? Any suggestions for those?
Any help is greatly appreciated. Thanks in advance.
Center - no
Amp-no
Sub-no
Amazon.com: Kicker CSC35 90W 3.5 Inch 2-Way Coaxial Car Audio Speakers (Pair) | 43CSC354: Car Electronics
Buy Kicker CSC35 90W 3.5 Inch 2-Way Coaxial Car Audio Speakers (Pair) | 43CSC354: Coaxial Speakers - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
