Stereo upgrade!!!
EdenZhiweis
I love my RAM, BUT… the base stereo BLOWS!!! So after much research I found a solution that did not involve me cutting 1 factory wire. It is a bit of a pain in the *** but I found harnesses and the right equipment to do the job. Most of the items were available from Amazon or Crutchfield. I replaced all of the door speakers with kicker 3way 6x9’s. Kicker 3.5’s in the dash corners and a 12” sub in a ground-shaker enclosure.
I used an audio control LC-7i to convert the signal to a kicker 5 channel amp. Also used a pac audio ANC-CH01. This cancels out the active noise control system and allows you to wire your amp using the factory wiring without cutting any of the factory wires. Finally my truck sounds as mean on the inside as it does on the outside.
EdenZhiweis
I used an audio control LC-7i to convert the signal to a kicker 5 channel amp. Also used a pac audio ANC-CH01. This cancels out the active noise control system and allows you to wire y Tweakbox our amp using the factory wiring without cutting any of the factory wires. Finally my truck sounds as mean on the inside as it does on the outside. Appvalley
issue got solved!!
