Starter button issues
einre
2019 Bighorn 5.7 the starter button does not recognize either remote, i have to press button with remote to start the truck. All remote functions work as they should. Anyone else had this issue, i'm thinking issue with the push button.
Do they unlock the door fine? Have you checked the FOB battery? Do you have a rear window leak?
All functions of both remotes work just fine the batteries in both are new, when i push the button i get key fob not detected message on the meter cluster.
When's the last time the truck battery was replaced? Have you tested your current one?
