Hi Everybody,
Bought a 2022 Big Horn 4x4 brand new. At about 5k miles I noticed a chirp/squeek coming from the rear driver side. The only time it is noticeable is when I turn into/back out of my drive way (which is on a little bit of an incline) while turning OR, when I'm driving slow on a gravel road with some pot holes. Of course I can't replicate the sound when the truck is parked and rocking it back and fourth/ side to side. I've heard about the brake clip issue so I tried spraying the clips with some lube and the sound still exists. Also sprayed the bushings where the rear sway bar is. I figured I reach out to you guys first before I send it into the dealership blind. It definitely sounds like metal on metal squeeking. I crawled under it and didn't notice anything loose or out of place. Anybody else having these issues??? TIA!!!
