Rayzram
- Aug 5, 2018
That looks terrible from the picture. I ordered the WeatherTech flaps on Thursday. I’m hoping they are much better than my WT floor mats.
the problem i see with the mopar flaps is they have a "pocket" area at the bottom. this area will collect debris and snow. i could seethes being one of those areas where a pressure washer will spit whatever it collects right back at you when washing. GATORBACK or WEATHERTECH for me when my truck arrives.Not really impressed with the fit. Ram could do better. Horrible lines in regard to tire coverage and not flat to the ground. Maybe im just super picky, but they should come down in line with the tire and sit flat across the bottom.View attachment 6301View attachment 6300
Wish i would have researched better. Them look amazing
The weathertechs? No I haventHas anyone had issues with the fronts rubbing I just installed them on my rebel and the fronts are rubbing bad
Sorry I should of been more specific it's the mopar onesThe weathertechs? No I havent
Stock tires? Mine clear but not by a ton i assure you running factory 20'sSorry I should of been more specific it's the mopar ones
I'll try and get some pictures later I have factory 18's and I believe 33 inch tires I'm going to try a heat gun later too to mold them back it almost looks like they curve in, I didn't have this problem on my 16 rebel maybe I got a bad mold but who knowsStock tires? Mine clear but not by a ton i assure you running factory 20's
They do curve in and it drives me nuts. Horrible fit in every aspect.I'll try and get some pictures later I have factory 18's and I believe 33 inch tires I'm going to try a heat gun later too to mold them back it almost looks like they curve in, I didn't have this problem on my 16 rebel maybe I got a bad mold but who knows
Yeah I tried a heat gun to make then flat and it's not rubbing as bad anymore but I think I'm just going to order weather techs for the from and give up on the mopar fronts and keep the rearsThey do curve in and it drives me nuts. Horrible fit in every aspect.
I wished I read your post and viewed these pics before I ordered the Mopar Splash Guards...I agree with you! Put the guards on yesterday and removing them today! Now to check out Wathertech...Not really impressed with the fit. Ram could do better. Horrible lines in regard to tire coverage and not flat to the ground. Maybe im just super picky, but they should come down in line with the tire and sit flat across the bottom.View attachment 6301View attachment 6300
Return them and get weathertechs,,,,horribleNot really impressed with the fit. Ram could do better. Horrible lines in regard to tire coverage and not flat to the ground. Maybe im just super picky, but they should come down in line with the tire and sit flat across the bottom.View attachment 6301View attachment 6300
I seen where Husky makes a set...anyone running Husky Flaps and could post a pic of them?Return them and get weathertechs,,,,horrible
