Speedometer Backlight?
KellanCarson
I was driving yesterday and noticed that the backlight on both the tachometer and speedometer (pictured here) is inconsistent. It’s almost as if I have a light out behind the dash, but I don’t - I turned the truck on last night and everything seemed fine. It’s only noticeable omegle xender during the day. Almost like the light is drowned out by daylight the further it gets from the source.....
Anyway, I’m rambling, but I was curious if anyone else has this, see picture below, hard to capture but 50-80mph are way brighter than the lower or higher end of speedo - same goes for tach with 3-5. 2019 limited.
I was driving yesterday and noticed that the backlight on both the tachometer and speedometer (pictured here) is inconsistent. It’s almost as if I have a light out behind the dash, but I don’t - I turned the truck on last night and everything seemed fine. It’s only noticeable during the day. Almost like the light is drowned out by daylight the further it gets from the source.....
Not seeing any pictures in your post, however, I'm pretty sure I saw a thread similar to yours not too long ago here regarding the same issue. Might want to try to search and find that thread or maybe someone else here will chime in to help.
