On the standard 6 speaker system the 3.5” in the dash are 8 ohm 15 watt the two 6x9” in the front doors are 4 ohm 15 watt and the two 6x9” in the rear doors are 4 ohm 15 watt. Hope this helps.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
