It can be made to fit. I was able to get my 35x12.50 bfg ko2 on a 10” wide rim in the stock location, but I had to trim about a 1/4” or so off the back of the hitch. Basically trimmed right up to the weld. Without trimming it forced the tire to rub the trac bar and every time the truck moved you could hear it squeak, trimming gave it just enough clearance.
I was able to fit a 35" 12.5" BFG in the spare tire location, but it required some cutting and welding. Initially I tried cranking the 35" up into the spot, because I saw a couple folks on the forum stated they fit a 35 in there, but it didn't work on mine, as it hit the panhard bar.
I moved the center section of the hitch back about 1.5" to get about 1" between the tire and the panhard bar. Been running about 20K miles and it the tire does not rub on the panhard bar.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
