I am hoping someone can help with this issue Ive seen listed back in October. I have a 2019 2500 with Uconnect 12. The Sirius radio presets worked fine for 1 1/2 years until recently and now they disappear every time I shut the vehicle off and restart. Here is what I have tried to fix this issue from this forum as well as from other sources (dealership and You Tube):
Talked to numerous service tech's at the dealership and no-one has any solutions other than what was listed above.
I have seen these problems have been discussed on this forum before and would hope that a solution would have been found by now.
Any help or suggestions would be appreciated.
- I had Sirius XM send a refresh signal to my radio - did not work
- A bulletin from FCA says that the most common problem is the radio is in Demo mode and to "go to the Sirius Page and exit demo mode" - my radio is getting all Sirius stations and my account is active in my name in the settings section, so I don't think it is in demo mode?
- I watched the You Tube video where they suggest that you create your own user and avatar (in Sirius settings) and then save it. Then assign presets to that user in the main radio screen. I tried this and the radio doesn't remember the user name and avatar that I set-up when I go to the media screen, so there is no ability to assign presets from my favorites to that name.
- I removed connections to the main battery and then reconnected - no luck.
- I have talked to siriusxm rep with no help.
