Side to side / 4 corner levelling an air ride.
BMRAMAU
I have a 21 Limited with Air ride.
I have installed the readylift 1.5” levelling kit, I never measured before the level but my levels are now all out.
Passenger front side of the car was sitting an inch higher than the drivers side front.
I used a revel link to lower the passenger side only and left stock link in the drivers side and it lowered both. So still out of level side to side?
Same at rear but not as dramatic, I do have a larger fuel tank that’s full but that shouldn’t make the whole car lean.
Measured on a few different slabs. What could cause this?
My RAM is stock with air ride. It was 1" of in the rear, higher on the drivers side if I recall correctly. Took it back to the dealer and they recalibrated the system, that fixed the problem and it has been level since then.
You can set all 4 corners individually with AlphaOBD.
