Side mirrors in reverse
2025 Ram Limited
I tried the tilting side mirrors in reverse option but hate it. They fold down too far and you don't see anything but the ground. I assume it is for watching the curb but they tilt so far it becomes unsafe. Anyone else have this issue or is there a way to adjust the tilt? I turned it off for now.
No way to adjust them on a 2025, but on the 2019 to 2024 there is a setting that can be adjusted using AlfaOBD. Someone said that if you have the seat memory settings, you can set one of them with the mirrors pointing where you want and use that when backing up. Then use the other to set it back. Of course if you use the memory for 2 different drivers, that won't work.
Not a bad idea actually. Thanks.
