Should I go with 35s?
detroitm2
SE Michigan
I'm sure this is asked all the time. But I need some advise :)
I'm buying new tires. My rebel has air suspension, and a leveling kit on the front.
I'm looking at getting a set of BFG KO3 35x12.5x18 to put on the stock wheels for the time being.
I may replace the wheels, but it won't be until after the winter. In the meantime, I have a set of 1.5" wheelspacers to help clear the UCAs.
How much of a headache am I making for myself? Will I have to do a ton of trimming?
Other question is, can I still use aero and entry/exit mode on my air suspension without rubbing?
Thanks in advance!
I'm running Toyo Open Country AT3s that are 295/55/22 and a Rough Country level kit. I drive it in Aero mode since it seems to ride better and you can't even tell. The pic is in Standard mode. I do have entry/exit mode but can't use OR1 or OR2.
I decided to just go with 285/75r18's for now. When I get new wheels, I'll probably bump up to 35x12.5's.
