Shopping wheels and tires. (20x9 +1 offset - 33x11.5) Leveled 2021 Laramie
Mike F.
Is anyone running this set up?
I'm trying to upgrade to a 33 inch tire without a lot of poke.
I'm looking at the Fuel Sigma and the Celsius wheels size 20x9 +1 offset. I understand that the 1 increase in wheel width will add 1/2 inch to the inside and outside and the offset from 19 stock to 1 will give back almost 3/4 of an inch making the inside of the rim 1/4 inch out from stock. So that wheel and offset should clear everything. The question now is will a 33x11.5 clear the control arm and fenders and liners without trimming. I have no issues with heat gun molding the liners but I'd prefer not to have to do any cutting. The truck is leveled with Bilstein 5100 2 inch in the front. Will be moving to 2.6 front and 1 inch rear, new control arms (ready lift) with the new wheels.
Any advice would be appreciated.
Thanks
you will be fine with those wheels and tire size. You will probably need to clearance the inner wheel wells and possibly take the front mud flaps off. But you are good as far as clearing UCA. Both of those wheels are great also!
Thanks for the reply. I guess I'm just looking for some reassurance before I spend the money. I'm trying to keep this truck looking clean. Minimum poke and a slight lift. I like the Sigma wheels but I found a deal on the Celsius 20x9 wheels for under $1000. Decisions to make.
I’m on a 0 offset and come damn near flush with my fender flares so I’m sure +1 would be inside or flush perfectly.
I would say with 90% confidence your setup would work w/ minimal heat gun surgery etc.
