Service shifter
flakkoflores
I have a 2019 RAM laramie with 94k miles a couple days ago the service shifter chime came on didnt think nothing of it..fast forward to today 5.13.24 the dash lit up like a christmas tree the wipers went crazy the fan was going wild power steering went out. I hear alot of people been having the same problems anyone have a clue as to wut the solution was to the problem
Have you ever replaced your battery?
  • Like
Reactions: c3k
Yes i replaced starter and alternator as well problem still persists
Water intrusion in the back, module failing, poor ground connection, just to mention few possible causes.
What DTC`s are being thrown?
Man like 10 of them popped up but its something that has to do with can bus idk wut that means
Hello all I’ve been dealing with this service shifter/Park sense sensor/Auto start disable! Light issue for months. I just recently discovered that ram Chrysler Jeep Dodge has issued a recall on the power control module (PCM). If you contact the dealer and give them your VIN they will conduct a software update on your vehicle. Please see the link provided Look for Vehicle Recalls | Official Mopar® Site
As described, I've had the same issue (2019 Ram 1500 Big Horn): Park assist (front and rear), service shifter and oddly, the autocorrect shifter error. Errors are intermittent not consistent. However, codes I've received indicate a network communication error. As a matter of history, I did replace the 3rd brake light as indicated in the extended warranty, but under closer examination noted a leak in the back window (both "t's" on the window frame leaking water; clearly another issue Ram should be aware of - several YouTube videos of the same issue). Has anyone had any success submitting damage subsequent to the faulty brake light which allowed water intrusion (potentially impacting the RF module)? The warranty extension seems to acknowledge break lights are leaking water into the cab. Reasonably, said water leak would also potentially compromise the interior components including but not limited to modules (i.e. RF module located behind the backseat).
