Service Electronic Stability Control warning on 2021 RAM 1500 — won’t shift or fully shut off
DarthVoita
Here’s a fun one.
I was out driving yesterday in the Arizona heat. You know, a casual 116°, so of course I waited until the sun went down to run errands. I get in my 2021 RAM 1500 (just under 50k miles), and right off the bat, Apple CarPlay isn’t working. The truck’s not recognizing my device, which happens from time to time. No big deal.
I go about my errands, make a quick stop, and start heading home. About half a mile from the house, I get an error on the dash: “Service Electronic Stability Control.” Not ideal. Then, as I pull up to a light to make a left, I can feel the transmission hesitating, like it’s struggling to shift properly.
I make it onto my street and begin to back into my driveway. I shift into reverse... and nothing happens. The same warning flashes again. I try to throw it into drive, and instead, I get a message saying the truck is overriding my input and automatically shifting into park. Awesome. Now I’m sitting diagonally in the middle of the street, half-backed in.
At that point, the truck won’t shift out of park, and I keep getting that same “Service Electronic Stability Control” message. Even worse? It won’t shut off completely—it’s stuck in ACC mode. Eventually, I figure out how to get it into neutral, roll it to the curb, and disconnect the battery to keep it from draining overnight.
So here’s my question: what am I dealing with here?
Could this be electrical, considering the funky behavior with CarPlay earlier? A dying battery? Or worst case... something transmission-related?
Appreciate any insight or guidance from anyone who’s dealt with something similar.
UPDATE: Reconnected the battery, and no error messages occurred. Drove it around the block a couple of times. No issues. Which is terrifying. Now I have to wonder if this is going to happen again? What the heck happened?
Here’s a fun one.
I had a similar issue a while back with funky alarms and shortly after the truck wouldn’t start. Turned out it was a battery slowly dying. I jumped the truck about 3 different times in one day and each time it would test fine afterwards(I didn’t know that jumping a battery gives it enough juice to test “good”). After a new battery the warning lights disappeared.
However, just a few days ago the CarPlay issue is back. No cable can seemingly get my CarPlay to appear however I can see my phone connects via Bluetooth to make calls etc. but I can’t have maps up or even listen to music. Very annoying to say the least.
I have had issues with two apps, Android Auto and BluOS not connecting. Both were resolved by uninstalling the app and then re-installing it on the Android phone, even though the apps were up to date. I believe it has to do with deleting the cache. Apple is probably no different.
