Holdbrooks
- Mar 30, 2021
I have a ‘19 Laramie 4WD with eTorque that sat idle for about 10 days while on vacation. Upon starting it for the first time, the messages “service antilock brake system” followed by “service electronic stability control” followed by “4WD system temporarily unavailable” appeared in the dash. Cruise control will not work either. Notably, there was a good bit of corrosion visible on the rotors. Even though the check engine light is on, no error codes were detected. Disconnected the battery, but issue remains. I also checked the fuses which seemed fine.
Any advise on what steps to take next would be greatly appreciated.
