Meodom
- Jan 17, 2023
Okay……I’ve come to the point in my mod I’ve been avoiding! I have my fog lights in, the OEM harness installed, Mike’s harness installed and the wire run through the firewall. It’s time to tackle pinning the BCM. I’ve read countless threads in prep to tackle this. I’m looking for any tips and encouragement I can get before I start what looks to be a real pain in the a$$!
I’ll take any tips y’all throw my way!
Some specifics I’d like to ask about.
1. The right fog (C4) connection is done one handed and seemingly in the blind. Tips on releasing the lock bar on the cover and popping the wire harness out of the cover one handed? Seems you need a small screw driver to pry the harness out of the cover. How is that accomplished one handed?
2. Same as above, is a screwdriver not required to detent the tab locking the harness cover locking bar to release it?
3. Anything I can/should try to move out of the way other than the connections in the BCM to the left of C4?
4. Anyone out there attempted this and couldn’t get it done?
5. How long did it take?
6. Should I remove the kick plate under the steering wheel for better access?
7. Finally, how many beers do I need to buy for this part of the project!?
