Seat heating
cristi
I have a problem with the right front passenger seat, the heating comes on and off immediately, has anyone ever encountered this problem?
MrMisk
Heater element could be shorted causing the system to shut down, wire issues or a bad module
djevox
VP of Creative Thinking
MD
All update this post later with some strategies you can use to test if you would like. Do you have access to a multimeter? If not, you will need one. You will also need an amp clamp for a multimeter. Harbor freight has both very cheap, and Home Depot has them relatively cheap.
if you don’t want to buy those things and are still under warranty, just take it into the dealer.
RAMTUNINGPOLAND
Hi, I have exactly the same problem, did you manage to solve this problem?
I put in new seats from another Ram and still the same, so my seat heating mats are definitely OK. Only the driver's seat heating works, when I click the passenger seat heating on the screen, it automatically turns off after 3 seconds. The computer shows an error B2353-13
(right heated seats power supply-circuit open)
I don't know where to look anymore, the installation looks good.
