AZRammer
- Oct 1, 2019
RAM 1500 Limited has the cheapest, thinnest, most worthless PLASTIC trans oil pan. i was in a very remote part of Coconino National Forest (northern Arizona) scouting for the upcoming Elk season. small branch busted through the plastic pan and pierced my transmission, total fluid dump. and when a sealed 8-speed has total fluid loss, you are STUCK. no option to field patch & refill. shifter nob will not shift to neutral. if that wasnt bad enough, the manual release (orange tab) will not engage neutral either. basically you are up sh*t creek. rear wheels frozen.
I had to disconnect rear differential just to free up rears & drag it out. enough of the sob story.
Any skid plate recs for a lifted 5th gen '19 1500 (4" BDS)?
thank you kindly
thank you kindly
